BloodyIron
- Jul 11, 2005
Hi Folks,
I'm hoping to see a seriously [H]ARD answer here, because I'm running out of ideas.
I'm talking about two identical systems that are used for hosting VMs, which are based around the following parts:
I'm monitoring the health of these two systems, so I can get alerted when problems arise (like this one). Suddenly I am finding that one of the nodes is running 10oc hotter all the time (and under heavy load the temps spike well up to 70oc). I have dusted it out, several times, replaced the thermal compound between the HSF and the CPU, several times, and I know for a fact the fan on the HSF is spinning because I get RPM readings from it.
The load between the two systems is effectively equal, I balance evenly (as best I can) between them. Yet after a full day of "burning in", this node is still 10oc hotter than my other one.
I am really at a loss as to what is going on here. Can anyone advise? :/
- AMD's FX-8320 (stock HSF)
- Asus Motherboard model M5A78L-M/USB3
- Good one "idle" temp : 49oc , max temp during backups : ~55oc
- Sad one "idle" temp : 59oc , max temp during backups : ~68oc
