BinarySynapse
- Feb 6, 2006
One thing to note about your last paragraph, while fusion produces four times more power per reaction than fission does, fission fuel being solid (vs gaseous fuel for fusion) means it has far more power generation capacity. What fusion brings to the table is nearly unlimited fuel and far less dangerous or long term waste if we can ever figure it out.Embrittlement doesn't work that way. When a neutron hits something with enough force it is degraded. This process is similar to how a photon degrades matter(ie sunlight) but much more high energy. Yes radioactive elements can be created via neutrons. No it isn't high level waste. No it is not generally capable of producing more radioactivity. Yes it generally is very short dangerous half-life's that are created.
The issue with people who have no actual contact with the nuclear industry is that they are told all nuclear waste is some horrific thing they should avoid. The reality is most of it is basically harmless. You can find more long term exposure in new york due to radon gas than you will EVER GET from working in a waste disposal site. What you don't seem to understand is most "waste" is less radioactive than every day encounters after an extremely short time. Most of the dangerous radiation is also alpha.... which can be shielded by a sheet of paper. The only time such material is dangerous is if you eat or drink it. Since most of the waste does not dissolve in water and will not decay on its own it is no different than radioactive ORE.
IE your fears are unfounded. Trust me when I tell you that you are exposed to more radiation from airplanes than you will ever be at risk from from nuclear waste. The amount of background radioactives in your life are far more a concern to you than a piece of graphite buried in a glass filled cask in the desert. Living down wind(50km+) from a coal power plant will give you more health risks from radioactivity than living next to a modern nuclear waste dump.
As to fusion power and its waste products.. Yes tritium is required to start an ITER design. After the reaction is stable however only deuterium and lithium are required to sustain the reaction. Fission reactors are not going to go away simply because sometimes you don't need to power half a planet from one reactor and there are certain things we need to power our society that can only come from a fission reactor(crapton of medical tech). Everyone has doubts for fusion. The reality is people think because the sun requires stupendous mass that that somehow invalidates the science. The reality is we pretty much know fusion can happen already and we know it will be massively power positive. The only challenge is finding out how to do that with our current technology or having to wait until we have the technology to actually make the thing work. This is not uncommon. We knew that cellphones and lithium batteries were a thing long before we as a species even had the ability to produce such things. Sometimes you have to wait for material science to catch up. Sucks but it is what it is.
