Full Spec Dell G7 or Asus GU501GM (Zephyrus M light)
Discussion in 'Mobile Computing' started by Brownstone, May 4, 2018.
  1. Brownstone
    Brownstone Gawd
    874
    Mar 12, 2007
    Hello!
    Before I pull the trigger I need some input... I am between these two laptops.
    The Asus is the BB exclusive Zephyrus, I believe the only difference is it has a 120hz IPS instead of a 144hz?
    Between the Dell and Asus the difference is the use of 1060 Max Q vs full 1060, the 60hz IPS on the Dell and the aluminum chasis on the Asus?
    I would be buying an open box for 1350 so it is a 150 usd difference. I am torn if it is worth the extra cost of the Asus. Opinions? Thank you!
    I could not find anything solid on the Asus
  2. zamardii12
    zamardii12 2[H]4U
    2,376
    Jun 6, 2014
    Well, it depends on what is most important to you. Could you provide us with the link to the Zephyrus? I am seeing 2 on Best Buy's website. I'd like to know which one specifically you are considering.
  3. Brownstone
    Brownstone Gawd
    874
    Mar 12, 2007
  4. iRUSH
    iRUSH Gawd
    746
    Jun 4, 2013
    A hopped up Civic vs a low end BMW
    I’d go with the Asus. I have a G7 7588 in my possession.
    The Dell is great at $1k but spec’d out is getting into better product territory.
  5. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,594
    Dec 23, 2001
    With a 4 cell battery on the asus dont expect great battery life
  6. zamardii12
    zamardii12 2[H]4U
    2,376
    Jun 6, 2014
    I'd go with the Dell. 12% off coupon with "SAVE12" at checkout and 15% cash back with Ebates. I just purchased a spec'd out G3 with the same specs as the Asus. The coupons and cash back turned my otherwise $1100 purchase into a $833 one.
    (Sorry mods if this isn't allowed but figured i'd help OP out, but delete if need-be)
    If you sign up with Ebates then you get $10 instantly. https://www.ebates.com/r/ZAMARD3?eeid=28187
