I can access/read/write to this ftp site with a client fine.
When I try to use it through a command prompt I can connect, enter credentials, change directories, but when I write to it using "put filename.txt" it says connection closed by remote host.
Is my syntax wrong. All the info I've found online says no. But clearly something is messed up.
Eventually want to write a script for a nightly backup.
