FT: Be Quite! Dark Rock Pro 4 for GPU
Discussion in 'For Sale / Trade' started by PuppeteerNessus, Aug 10, 2019.
  1. PuppeteerNessus
    PuppeteerNessus 2[H]4U
    2,412
    Nov 20, 2007
    I've got a "new" Dark Rock Pro 4 that is open box, but never installed. The case I purchased this for wasn't wide enough, so I did a test fit and then put it right back in the box. I'm looking for the best GPU I can get as a direct trade here.
    Heat is under puppeteernessus
    Thanks!
  2. dat722
    dat722 Limp Gawd
    327
    Jan 20, 2007
    I have a AMD Gigabyte 7950
  3. PuppeteerNessus
    2,412
    Nov 20, 2007
    Might be interested, let me keep this alive for a bit longer to explore other options. Thanks
  4. thebufenator
    thebufenator [H]ard|Gawd
    1,182
    Dec 8, 2004
  5. dat722
    dat722 Limp Gawd
    327
    Jan 20, 2007
    Damn I got one upped
    thebufenator and DF-1 like this.
  6. PuppeteerNessus
    2,412
    Nov 20, 2007
    Deals looking better. Let's see what another day pulls before I pull the trigger. What kind of timeline are you on bufenator?
    SamirD likes this.
  7. OhSigmaChi
    OhSigmaChi [H]Lite
    123
    Jan 27, 2019
    I have a Sapphire Pulse RX 570 4gb just collecting dust.
    thebufenator and SamirD like this.
  8. OhSigmaChi
    OhSigmaChi [H]Lite
    123
    Jan 27, 2019
    whew, just checked the specs and this is listed as .2cm less than the max CPU cooler height of the case I want it in!
    SamirD likes this.
  9. PuppeteerNessus
    2,412
    Nov 20, 2007
    Didn't even see your message. I'll keep it open one more day and maybe I'll get a Vega 64 ;)
    Otherwise, I'm good for the 570, just let me look one more day.
    SamirD and OhSigmaChi like this.
  10. PuppeteerNessus
    2,412
    Nov 20, 2007
    Last ditch bump for that Vega :)
    thebufenator likes this.
  11. PuppeteerNessus
    2,412
    Nov 20, 2007
    edit - attempted trader had no heatware. let's try this again
  12. OhSigmaChi
    OhSigmaChi [H]Lite
    123
    Jan 27, 2019
    wow, ok... good luck with your trade.
  13. OhSigmaChi
    OhSigmaChi [H]Lite
    123
    Jan 27, 2019
    Hope you guys have heatware accounts with tons of feedback:pompous::pompous: and aren't some unwashed heathen like me:clown:
  14. syn0s
    syn0s Gawd
    612
    Jul 7, 2006
    I've got positive heat and I think a couple r9 280x gpus, maybe an R9 380 even... not sure if those interest you at all?
