FS: Titan X (Pascal) Hybrid
Status
Not open for further replies.
blade52x
SOLD
This is the 3854 core version - Images Here
I've removed the AIO and put the vapor chamber cooler back on, so it is effectively an air cooler Titan X(Pascal) with the EVGA Hybrid shroud. The AIO and original shroud are included as well.
Heatware is under njdevilsfan87 (87-0-0). Local pickup at 90403 available.
Armenius
I Drive Myself to the [H]ospital
I don't recall needing to use different screws when I installed the hybrid cooler on mine. Are you referring to the ones that secure the pump to the GPU? I'm pretty sure those may have been the only ones that were different.
Status
