$390 shipped CONUS
This is the 3854 core version.
It comes with original box and cooler, but it will need replacement thermal pads if you decide to remount the original cooler. Additionally I cannot locate the original cooler's screws, so if you decide to remount the cooler you will need to find a replacement set. I am not sure if the Hybrid's screws may be used in place. Because of this I've discounted the price slightly compared to the last one I've sold to make up for needing to find a replacement set. The tubing on this one looks a bit worm near the card (see image) and radiator - but it's just the outer cloth sleeve coming a bit loose after being bent in different positions many times.
Heatware is under njdevilsfan87 (87-0-0). Local pickup at 90403 available.
