FS: Thermaltake Water 3.0 Ultimate all in one water cooling 360mm
DSLisFREE
I have for sale a gently used Thermaltake Water 3.0 Ultimate 360mm size. This is the NON-rgb version. Includes all original accessories and box.
Asking 75 Shipped.
Compatibility Intel
LGA 2011
LGA 1366
Core i7
LGA 1150/1151/1155/1156
Core i7/Core i5/Corei3
AMD
FM2 / FM1
A-series
AM3+ / AM3
Phenom II/Athlon II/Athlon/Sempron series
AM2+ / AM2
Phenom II/Phenom/Athlon/Sempron series
*Chassis Compatibility: Core V71 & Urban T81
Water Block Material : Copper
Pump Motor speed : 3600+-150 RPM
Rated Voltage : 12V
Rated Current : 325 mA
Fan Dimension : 120 x 120 x 25mm
Speed : 1000~2000RPM
Noise Level : 20 dBA
Rated Voltage : 12V
Rated Current : 0.3 A
Max. Air Flow : 99 CFM
Connector : 4 Pin
Radiator Dimension : 393x 120 x 27 mm
Material : Aluminum
Tube Length : 326 mm
Material : Rubber
Weight 1.32 kg
http://www.thermaltake.com/Liquid_C..._One/C_00002345/Water_3_0_Ultimate/design.htm
