Essentially $1/GB + shipping (shipping not included). I have a UPS account with daily rates so I can ship either UPS or USPS. I'll charge actual shipping rates. I prefer UPS as they're so much better than USPS. Payment via Paypal, or I can send you a paypal invoice so you can pay by cc if you don't want to use paypal. I'm a bit flexible on pricing and shipping depending on how many you're getting so feel free to send me offers--I'll try to work with you however I can to make a deal happen. Feel free to reach me here or text me, 615-512-5520.
4GB DDR2 667 CL5 ECC 2RX4 PC2-5300F-555-11-E0 Memory modules by Samsung or Micron. 50+ modules available.
Each module has been 100% tested overnight with MEMTEST86 in my Dell PowerEdge 2950.
Samsung part# M395T5160QZ4-CE66
Micron part# MT36HTF51272FY-667E1D4
Sun part# 501-7954-01
Fujitsu part# CF00501-7954 Rev 01
0 Samsung modules currently available
0 Micron modules currently available
Compatible with the following and more:
Apple Mac Pro 3,1 A1186 EMC 2180 MA970LL/A 2008 3.1
(will only run at 667Mhz, not 800Mhz, and may need additional cooling)
Apple Mac Pro 2,1 A1186 EMC 2138 Z0D8 MA356D/A, MA356J/A, MA356LL/A, MA356TA/A, MA356TH/A, MA356ZP/A 2007 2.1
(may need additional cooling)
Apple Mac Pro 1,1 A1186 EMC 2113 MA356D/A, MA356J/A, MA356LL/A, MA356TA/A, MA356TH/A, MA356ZP/A 2006 1.1
Apple Xserve 1,1 A1196 EMC 2107 MA409LL/A Late 2006
Dell Poweredge 1900
Dell Poweredge 1950
Dell Poweredge 1955
Dell Poweredge 2800
Dell Poweredge 2850
Dell Poweredge 2900
Dell Poweredge 2950
Dell Poweredge M600
Dell Poweredge M605
Dell Poweredge R900
Dell Poweredge SC1430
Dell PowerVault DP500
Dell PowerVault DL2000
Dell Precision 490
Dell Precision 690
Dell Precision 690n
Dell Precision R5400
Dell Precision T5400
Dell Precision T7400
Dell P/N : SNP9F035CK2/8G, SNP9F035C/4G, A2257185, A2257233, A2257181, A2257180, A2257179, A2146192, A2257184
IBM BladeCenter HS21 (8853-xxx)
IBM IntelliStation Z Pro (9228-xxx)
IBM System x3400 (7973, 7974, 7975, 7976-xxx)
IBM System x3500 (7977-xxx)
IBM System x3550 (7978-xxx)
IBM System x3650 (7979-xxx)
HP-Compaq Proliant BL20p G4
HP-Compaq Proliant BL460C
HP-Compaq Proliant BL480c
HP-Compaq Proliant BL680c G5
HP-Compaq Proliant DL140 G3
HP-Compaq Proliant DL160 G5
HP-Compaq Proliant DL180
HP-Compaq Proliant DL360 G5
HP-Compaq Proliant DL380 G5
HP-Compaq Proliant DL580 G5
HP-Compaq Proliant ML150 G3
HP-Compaq Proliant ML350 G5
HP-Compaq Proliant ML370 G5
HP-Compaq XW460c
HP-Compaq XW6400
HP-Compaq XW6600
HP-Compaq XW8400
HP-Compaq XW8600
IBM BladeCenter HS show contact info -xxx)
IBM BladeCenter HS21 XM (7995-xxx)
IBM System x3450 (7948-xxx)
IBM System x3650 (1914-xxx, 7979-xxx)
Sun Fire X4150 Server
Sun Fire X4450 Server
Sun SPARC Enterprise T5220 Server
Sun SPARC Enterprise T5240 Server
Sun SPARC Enterprise T5440 Server
IBM 46C7420, Sun SESX2D1Z, Sun X4290AF, DELL A2257185, DELL A2257184, DELL A2257179, IBM 45J6193, HP 397415-B21, HP EM162AA, Sun X4402A, Sun X6382A, HP 466440-B21, IBM 40V6419, IBM 43R1773, HP 483403-B21, DELL A2146192, HP 397415-S21, DELL A2257233, IBM 43R1710, DELL A2257178, DELL A2257180, DELL A2257181, DELL A2257182, DELL A2257183, DELL A2257232, Kingston KFJ-BX667K2/8G, Kingston KTA-XE667K2/8G, Kingston KTH-XW667/8G, Kingston KTH-XW667LP/8G, Kingston KTH-XW9400LPK2/8G, Kingston KTL-TSD10K2/8G, Kingston KTM5780LP/8G, Kingston KTS4400K2/8G, Kingston KTS6380K2/8G, Kingston KVR667D2D4F5K2/8G, Kingston KVR667D2D8F5K4/8G, Kingston KVR667D2Q8F5K2/8G, Kingston KVR667D2Q8F5VK2/8G, Fujitsu S26361-F3263-L524, Fujitsu S26361-F3263-L624, Kingston KTD-WS667/8G
39M5797, 397415-B21, MA507G/A, A2146192, A2257178, A2257179, A2257180, A2257181, A2257182, A2257183, A2257184, A2257185, A2257232, A2257233, A6993740, A2146192, A2257178, A2257179, A2257180, A2257181, A2257182, A2257183, A2257184, A2257185, A2257232, A2257233, A6993740, A2146192, A2257178, A2257179, A2257180, A2257181, A2257182, A2257183, A2257184, A2257185, A2257232, A2257233, A6993740, SO.FB8GB.M02, S26361-F3370-L469, S26361-F3263-L524, S26361-F3263-L624, S26361-F3263-L724
HP-Compaq 404664-B21, 416653-B21, 416654-B21, 416655-B21, 416656-B21, 435458-B21, 435459-B21, 447707-B21, 459483-B21
HP-Compaq 443527-B21, 443528-B21, 443528-xx1, 443529-B21, 443529-xx1, 443530-B21, 443530-xx1, 449316-B21, 449316-xx1
HP-Compaq 445196-xx1; 445197-xx1; 445198-xx1; 445202-xx1; 445203-xx1; 445204-xx1
HP-Compaq 438084-001; 438087-001; 438088-001; 438089-001; 451993-001
HP-Compaq 395570-B21, 395581-001, 409393-001, 416892-001, 416893-001, 416894-001, 417536-001, 417537-001, 417538-001, 417605-001, 419523-045, 458237-421, 458238-371, 458238-421, 458240-421, 459279-075, 459279-425, 470064-509, 470064-609, 470064-610, 470064-613, 470064-640, 470064-644, 470064-868
HP-Compaq 440940-B21, 440941-B21, 440942-B21, 440943-B21, 440944-B21, 440945-B21, 440946-B21, 442846-B21, 442847-B21, 442851-B21, 443671-B21, 490861-B21, 490865-B21
HP-Compaq RB439UA; RB440UA; RB441UA
HP-Compaq PW453EA, PW463ET, RV726AV
Oracle part number 501-7954-01
Mfg TN: 465765F-1206S4A0R2
Also available:
Mohawk M57554 Cat5e cable (free--just cover shipping)
ALL CABLE CLAIMED AS OF 5-2-2018
Unshielded twisted pair (UTP) category 5e cable for use in horizontal cabling systems as described in ANSI/TIA/EIA 568-B. The cable consists of #24 AWG solid bare copper insulated conductors, assembled into four tightly twisted pairs, with a ripcord, under an overall jacket. Print includes descending footage markers from 1000 to 0 on each 1000ft reel or box. This product and/or its manufacture is covered by US patent nos. 5424491 and 5563377 (PL).
This riser non-plenum rated cable is for use as a vertical run in a shaft and for general purpose communications use in accordance with Article 800 of the NEC. The cable is ETL (USA) and cETL (Canada) listed for this application by passing UL 1666 riser cable flammability test.
Supported applications include IEEE 802.3 10Base-T (Ethernet), 100Base-T (Fast Ethernet), and 1000Base-T (Gigabit Ethernet), ANSI.X3.263 FDDI TP-PMD, IEEE 802.5 4 and 16 Mbps token Ring, ATM up to 155 Mbps. Referenced electricals are sweep tested to 100Mhz. It should also support the new 2.5GBase-T (2.5Gbit Ethernet) as well as 5GBase-T (5Gbit Ethernet).
Features:
14 dB Minimum ACR at 100 MHz
4 dB Minimum - improvement in Near End Crosstalk vs. TIA/EIA 568-B Category 5
5e LAN is ETL Verified to Category 5e
.25 ns/meter Maximum Skew - tightly controlled propagation delay
Engineered for future applications
Complete specifications available here:
http://assets.twacomm.com/assets/pdf/31209.pdf
We're replacing a bunch of this unused cable with fibre. This cable was previously run, but never used. It has been cut to various lengths between 10ft to over 100ft since it was previously installed and has been rolled up properly for easy transport (no kinks or other harsh treatment that can result in problems later).
Usually this type of cable goes for around 17 cents a foot, but since we were just going to throw thousands of feet of this perfectly good cable away, I thought I'd see if someone out there wants a bargain on cable for a small office or home install. If so, feel free to call or text. If you have some computer parts to trade, that would be fine too. I really just don't want to have to throw something like this away, so almost any offer will be considered.
Dell Poweredge 1900
Dell Poweredge 1950
Dell Poweredge 1955
Dell Poweredge 2800
Dell Poweredge 2850
Dell Poweredge 2900
Dell Poweredge 2950
Dell Poweredge M600
Dell Poweredge M605
Dell Poweredge R900
Dell Precision 490
Dell Precision 690
Dell Precision 690n
HP-Compaq XW460c
HP-Compaq XW6400
HP-Compaq XW6600
HP-Compaq XW8400
HP-Compaq XW8600
Also available:
Features:
