Will be updating as I add more. (I have a lot of hoarded crap to get rid of)
Also, for those who buy things, depending on your spend, you can choose freebies from the bonus list.
Read below for more details.
>> NOTE: Shipping not included <<
I will quote for shipping once you confirm what you want to buy.
USPS flat rate boxes and padded envelopes possible.
UPS may be applicable if someone wants a bunch o' stuff
>> All prices are NET to me - i.e. fees not included <<
** For Sale list **
>-----------------------Apple-----------------------<
1 x Apple Time Capsule (500GB) A1254 $20
Works great. Reset it to factory defaults and then did most basic setup from my iPhone - works fine (password is password)
Storage drive has been wiped and is ready to go. Should show up in Airport Utility. Set to DHCP.
1 x Apple Airport Extreme Base Station A1143 $10 ea.
802.11n (1st/2nd Generation - not sure which)
2 x Apple Airport Extreme Base Station A1408 $15 ea.
802.11n (5th Generation)
2 x Apple AirPort Express Gen 1 802.11n Wi-Fi access point (Airplay) A1264 $15 ea.
NOTE: All airports were tested to appear in Airport Utility before being reset to defaults.
In their current state they do NOT show up in Airport Utility.
You need to go to WiFi settings to see them and set them up.
TAKE ALL APPLE STUFF for $75 plus shipping
Arris SB6141 Surfboard Cable Modem $20
Used, tested, works. Comes with original power supply
Bought this to fix temperamental cable service due to an older modem. Worked perfectly. Later moved to FiOS.
* NEW * Linksys SRW-224P 100Mbit PoE GBIC switch $30
Tested, working, was removed for a quieter 8 port as I didn't need the capacity.
This has whooshy fans which you might be able to swap, however, is it worth it?
Would suit a workshop or outbuilding with PoE cameras as opposed to a living room
Ruckus ZD-1000 WiFi zone director $20
This is a tested, working Ruckus Zone Director 1000 sku 901-1006-US00
The unit has been upgraded to firmware version 9.3.4.0.21 then reset to factory defaults.
Unit comes with an upgraded 12V 3.0A power supply. (see pics)
Ruckus 7942 and 2942 WAPs $50
2 x 7942 B/G/N and 3 x 2942 B/G WiFi access points.
Tested, working, upgraded to 9.1.0.0.23 firmware.
>> Take the Ruckus WAPS and the ZD1000 for $60 plus shipping <<
Linksys WRT-54GL $20
As new, hardly used. Had it for six months as a test router to learn more about DD-WRT, then boxed it up after I moved to Unifi.
Comes with original power supply and has been updated to version "DD-WRT standard (VPN) v3.0 r44715" - dating from November 2020.
Sonicwall TZ-170 (APL14-034 Wireless UNR) $10
I had to go through serious butt-ache to reset this to factory defaults (set up a WinXP virtual machine to run old old IE6)
Having done this I uploaded the latest firmware, only to discover I had downloaded the Enhanced version of the latest firmware (only one available on the website).
Once booted with 3.2.3.0-6 I restarted to find it had deleted the previous standard firmware. So, it is currently running a trial of the enhanced firmware which has probably expired now.
Haven't booted it up since to see what happens. Can be had as a freebie for anyone who spends $50 if not already sold
Netgear FS116 $5
16 port 10/100 switch. Old school - heavy, metal construction. Tested to power up, not worth my time to test any further (can also be used as one of the freebies below if not sold)
ATI Radeon HD6450 $10
1 x DVI and 1 x Displayport. Full sized bracket only
SK Hynix DDR3L Registered HMT351R7EFR8A - $15
2 x 4GB 2Rx8 PC3L 12800R-11-12-B1 matched pair (top pair in photo)
Mushkin Silverline 992002 - $20
2 x 4GB DDR3 PC3-12800 9-9-9-24 1,5V
Worked fine when pulled. Upgraded to 32GB (middle pair in photo)
** Bonus Items **
ALL ITEMS ARE AS-IS Pick one item per $20 spent
Linksys SD-2005 switch - no power supply - tested to power up only
Dell DVD/CD Rewritable drive DH-16AES - low use, from a non-tech family's PC
Dell PERC H310 SAS adapter with one adapter cable (was working when pulled six months ago)
Fidelity pocket speaker - about 3" x 2" x 1.25" Cheap an tinny, runs on 2 x AAA batteries. Has a fold out 3.5mm TRS jack
Blackberry Curve on TMobile - purple. Comes with a slinky fake velveteen bag, also purple! Comes with a motorola charger. Worked when last tested a couple of years ago. Charging light comes on now.
15GB iPod 3rd Gen? Untested, not charged. Comes with basic earbuds
Logitech M186 wireless mouse (proprietary RF instead ?!?)
** For Sale list **
Netgear FS116 $5
** Bonus Items **
