I have used but in decent shape Lumia 1520 for sale. It is an AT&T branded phone so GSM only.
It is black and has 32gb of space. Screen has no cracks but has scratching on the left and right edges of the screen from the previous owner of the phone. Doesn't really mess anything up and not all that noticeable to me, especially when the screen is on. I tried to get a photo of this but its very hard to do. the one photo where you can see some of it looks like a crack but it is really just fine scratches. the back has some scratches but nothing terrible.
I have had screen protectors on it since I started using it years ago.
Comes with an Incipio NGP case. Small crack in the plastic by the power button.
Battery still works very well. I was a moderate user and it would last a good 2 days for me.
Does not come with SD card or SIM card. I will throw in a USB cable and wall charger. Is not original to the phone though.
Still is a great phone as long as you don't need heavy app support. 6 inch screen. Was factory reset. It does have windows 10 installed.
$60 shipped in a small flat rate box.
http://starshipvonbraun.com/ss/1520/DSC_0002.jpg
http://starshipvonbraun.com/ss/1520/DSC_0003.jpg
http://starshipvonbraun.com/ss/1520/DSC_0009.jpg
http://starshipvonbraun.com/ss/1520/DSC_0010.jpg
http://starshipvonbraun.com/ss/1520/DSC_0011.jpg
http://starshipvonbraun.com/ss/1520/DSC_0012.jpg
http://starshipvonbraun.com/ss/1520/DSC_0014.jpg
