FS: MSI AM4 Motherboard, Swiftech Pump, 2x120mm Radiator, LG G5 Phone, Icy Dock
Discussion in 'For Sale / Trade' started by sleepeeg3, Jun 8, 2019.
  1. sleepeeg3
    sleepeeg3 [H]ardness Supreme
    4,857
    Mar 4, 2004
    Shipping is via USPS First Class or Priority within the US. All items are working and sold as is. I am located in Alpharetta, GA and accept Zelle (banks' version of PayPal), Bitcoin or PayPal.
    My feedback:
    Heatware | eBay
    $70 shipped - MSI X370 Gaming Plus
    - comes with I/O plate only. Also, the stock heatsink mounting clips have been replaced with yellow ones.
    $75 shipped - Swiftech MCP 355 12v DC Watercooling Pump w/Alphacool Plexi top - Pump works great. The plexi top has several stress fractures, but still no problems. Pump can work with different tops ($2-30), which are designed to improve flow rates.
    $75 shipped - ThermoChill PA120.2 2x120mm High Performance Radiator - One of the biggest dual rads you can buy. No longer made. About twice as thick as a standard 120mm radiator. Compare this to an EK CoolStream XE 240 Extreme Performance radiator (280x130x60mm (L x W x H)) and it's even larger. Optimized for quiet, low speed cooling. There are multiple areas where the paint has chipped - I filled these in with a sharpie. Cosmetically, it's not perfect, but it will keep your rig cool.
    Specs
    • Dimensions: 304x128x61mm (L x W x H)
    • Plenumb: 10mm
    • Fitting Thread: 3/8" BSP
    • Construction: Brass Tanks & Tubes, Copper Fins
    • Finish: Black ElectroStat.
    • Weight: 1.6Kg
    • FanMounting Mechanism: Black Hardened Self-Tapper 6x1/2" (x8 provided)
    • Compatibility: FG120.2, NG120.2
    • Fan Center to Fan Center: Approx 130mm
    • Optimised for fans upto 130cfm.
    $20 shipped - 8 x Bitspower True Silver G1/4 Compression Fitting 7/16" ID 5/8" OD - BP-SLCPF-CC6 - Retail for $12.99 each. However, I think most of the silver layer has worn off, due to the galvanic corrosion between these and the copper in my loop. These kept my water loop clean for about 2.5 years, without needing to change the water (both natural biocides). Also includes 1 x Bitspower G 1/4" Silver Shiny Rotary 45 Degree IG 1/4" Adapter (BP-45R) - originally $9.99.
    $15 shipped - ICY DOCK 2.5" to 3.5" Bay SATA HDD & SSD Converter / Mounting Kit /Bracket (MB882SP-1S-1B)
    $10 shipped - IO Crest 2 Port SATA III PCI-Express x1 Card (SY-PEX40039)
    **********SOLD**********
    (SOLD) $200 shipped - Sapphire Radeon™ RX Vega 56 8GB (flashed to Vega 64) - reference card with Samsung memory. Flashed to Vega 64 speeds. Stock bios can be set with a flip of the switch.
    (SOLD) $60 shipped - LG G5 H830 (T-Mobile) - Great phone. Fast processor. Has a second rear camera for taking widescreen pictures. Front and screen are in mint condition - I had a glass screen protector on it and left the plastic on the fascia (both removed). I kept it in an Otterbox, but there are some scratches on the back. Comes with an unused, plastic screen protector, SIM card remover and USB-C cable - no adapter.
    20190907_203453.jpg 20190907_203531.jpg 20190907_203551.jpg 20190907_223613.jpg
    (SOLD) $80 shipped - 16GB (2 x 8GB) CORSAIR Vengeance RGB DDR4 3000 (PC4-24000) CL15 - Bling bling
    (SOLD) $60 Shipped - AMD Ryzen 5 1400 4-Core 3.2 GHz (3.4 GHz Turbo) Socket AM4 65W - Ships with heatsink/fan.
    (SOLD) $15 shipped - Samsung SSD 830 128GB 2..5" SATA-III MLC Hard Drive
    (SOLD) $80 shipped - i7-920 Bundle:
    (SOLD) $55 shipped - ASUS PRIME B350 PLUS AM4 AMD Motherboard - New replacement from warranty repair. Never used. Board and I/O plate only.
    SamirD and auntjemima like this.
  2. sleepeeg3
    4,857
    Mar 4, 2004
  3. sleepeeg3
    4,857
    Mar 4, 2004
  4. sleepeeg3
    4,857
    Mar 4, 2004
  5. sleepeeg3
    4,857
    Mar 4, 2004
  6. sleepeeg3
    4,857
    Mar 4, 2004
  7. sleepeeg3
    4,857
    Mar 4, 2004
  8. sleepeeg3
    4,857
    Mar 4, 2004
  9. sleepeeg3
    4,857
    Mar 4, 2004
  10. sleepeeg3
    4,857
    Mar 4, 2004
  11. ltcharles
    ltcharles Limp Gawd
    239
    Feb 23, 2010
  12. sleepeeg3
    4,857
    Mar 4, 2004
  13. sleepeeg3
    4,857
    Mar 4, 2004
  14. sleepeeg3
    4,857
    Mar 4, 2004
  15. sleepeeg3
    4,857
    Mar 4, 2004
  16. sleepeeg3
    4,857
    Mar 4, 2004
  17. sleepeeg3
    4,857
    Mar 4, 2004
    Happy 4th, America!
  18. sleepeeg3
    4,857
    Mar 4, 2004
  19. sleepeeg3
    4,857
    Mar 4, 2004
  20. sleepeeg3
    4,857
    Mar 4, 2004
  21. sleepeeg3
    4,857
    Mar 4, 2004
  22. sleepeeg3
    4,857
    Mar 4, 2004
  23. sleepeeg3
    4,857
    Mar 4, 2004
  24. sleepeeg3
    4,857
    Mar 4, 2004
  25. sleepeeg3
    4,857
    Mar 4, 2004
  26. sleepeeg3
    4,857
    Mar 4, 2004
  27. sleepeeg3
    4,857
    Mar 4, 2004
    Moar stuff added bump
  28. sleepeeg3
    4,857
    Mar 4, 2004
  29. sleepeeg3
    4,857
    Mar 4, 2004
  30. sleepeeg3
    4,857
    Mar 4, 2004
  31. sleepeeg3
    4,857
    Mar 4, 2004
  32. sleepeeg3
    4,857
    Mar 4, 2004
  33. sleepeeg3
    4,857
    Mar 4, 2004
  34. sleepeeg3
    4,857
    Mar 4, 2004
  35. sleepeeg3
    4,857
    Mar 4, 2004
  36. sleepeeg3
    4,857
    Mar 4, 2004
  37. sleepeeg3
    4,857
    Mar 4, 2004
  38. sleepeeg3
    4,857
    Mar 4, 2004
  39. sleepeeg3
    4,857
    Mar 4, 2004
  40. sleepeeg3
    4,857
    Mar 4, 2004
