FS: MacBook Pro 13 and HP OMEN 15-ax250wm Laptop
Status
Not open for further replies.
Brock
MBP:
$OLD
MacBook Pro (Retina, 13-inch, Mid 2014)
https://everymac.com/systems/apple/...-i5-2.6-13-mid-2014-retina-display-specs.html
8GB RAM
128GB SSD
Basically Mint
HP Laptop: $OLD
15-ax250wm - 15 inch
-Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
-12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
-NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated)
-250GB Samsung SSD Installed, Will include in the deal as a sweetener, a 512 GB Samsung SSD.
-Full HD IPS LED Display
-Windows 10 Home 64
Very very slight LCD imperfection only noticeable on black backgrounds. Appears as a white spot.
Pictures: https://imgur.com/a/RySNtXY
Shipping to US48 Only.
Offers via PM Only.
Heat and eBay under ifbrock
15 and
15-ax250wm
Thanks. Do you have any other high quality pics of the screen? I looked at the imgur link and the pic of the screen is kind of blurry for me. It may just be that imgur compresses the images.
Do you have a Heatware or ebay you can link to?
I can try to get some more that was the best I could get out though.
It's clean other than the indicated spot.
Added heat and eBay to OP.
Status
