Shotglass01
- Aug 26, 2005
Lian Li 7077B Aluminum Case. One 5 1/4 inch cover has holes drilled in it. 2 rear 80mm fans have been soldered together in to one connection. Comes with all four fans. 120mm front, 120mm rear, and the 2 80mm rear. Has additional 120mm top hole. $125 shipped.
Newegg item: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112050
