Upgrading a smaller PC to a full size pc. Good combo, just want an ATX And went Z370 for the build.
I am using an Enermax AIO 240mm cooler on cpu and it will run 4.6-4.7ghz YMMV. I do run it at 4.5ghz regularly though as I can run 4.5ghz at 1.275v set in bios as opposed to 1.325-1.35v for higher mhz. For me it wasn't worth the voltage/mhz gain to run it there regularly.
combo is board, retail box and accessories. CPU(retail-probably have box), and case. Case is in good shape, no damage I can see.
mobo: Gigabyte:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813128977
case:
Coolermaster.
MasterBox Lite 3 Micro ATX Mini Tower with Black Interior Fit Up to 240mm Radiator
https://www.newegg.com/Product/Product.aspx?Item=N82E16811119319
No ram included. No cooler included.
looking for $250 plus shipping
mobo: Gigabyte:
case:
Coolermaster.
