Noctua NF-P14 FLX 140mm/120mm + Coolink 120P 120mm + Coolink 1201 120mm + SilenX EFZ-100HA2 92/100mm + Samsung HS-223 DVDRW SATA - $30 CONUS
Selling a bundle with a bunch of high-end fans. The Noctua fan normally sells for $30 alone; each Coolink fan is equivalent to a Noctua 120mm (same parent company); the SilenX fan works on both 92mm and 100mm mounts and is very quiet. One thing to note, however, there is a small hairline crack on one of the NF-P14 blades. It does not affect performance or noise; you may repair it with some super glue if you are uncomfortable with it. Other than that minor defect, these fans are awesome and quiet! The drive is a Samsung HS-223 DVDRW SATA.
I would like to trade for a fan or pump controller that can properly handle my Koolance PMP-400 DDC3.25 pump; i.e. 20w, 12v max, 10v startup. The mCubed stuff looks really great - let me know what you have!
