I have a decent laptop for sale,it is from powernotebooks.com.Specs....
1.3 Ghz centrino
768MB's Ram
Hitachi 40GB 8MB Cache 5400 Rpm HDD
15" SXGA+(1400x1050) Screen
Dedicated 64MB ATI Radeon 9000 Graphics w/POWERPLAY[tm]
DVD/CDRW Combo Drive
Built in WiFi
Built in card reader
4 USB2 ports/Firewire/No PS/2
Battery is partially dead,I get about 1.5 hours with the CPU@595Mhz. and with low brightness just letting it drain.
1.25" thin,wieghts about 5.5-6Lbs
Brand new Targus Laptop Bag
http://usera.imagecave.com/cstafs/Laptop/IMG_1280-copy.jpg
http://usera.imagecave.com/cstafs/Laptop/IMG_1281-copy.jpg
http://usera.imagecave.com/cstafs/Laptop/IMG_1283-copy.jpg
http://usera.imagecave.com/cstafs/Laptop/IMG_1285-copy.jpg
Okay,now the problems...
The screen has some keyboard damage and a light scratch,it's not too bad and I have pics if you want them.Also a small part of the WiFi antenna sticks up onto the screen about 1/8th of an inch from the bottom,probably easily fixed if you wanted to try,but it never bothered me enough to do so.
Other then the above it has normal wear and tear,the top has a tiny ding in it which I believe is aluminum.
Asking for $400+shipping
Stuff I would take in trade....
Panasonic DMC FZ30S Camera
Thanks,
Chris
1.3 Ghz centrino
768MB's Ram
Built in WiFi
Thanks,
Chris
