FS: EVGA 980 Ti FTW GAMING ACX 2.0 $240
Status
Not open for further replies.
zmhaha
Upgraded to a z370. Selling the old setup.
i7 6700k with original box.
Delided. I did not reseal the HIS to minimize the gap between the die. I will reapply some thermal grizzly Kryonaut before shipping it out and leave the CPU in the mobo socket.
I used to run it @ 4.5Ghz default everything until I delided last month and bump it up to 4.8Ghz (all cores w/ HT on of course) 1.3v under torture tests, so its a pretty good overclocker. I used offset mode with +100mv, and load line calibration set to flat curve. As for cooling, just a Corsair H100i, nothing fancy. Temp is about 65C under torture test, but can go upto 75C for prime95 maximum heat option.
ASRock Fatal1ty Gaming Z170 Gaming-ITX/ac LGA 1151
Comes with original packaging and paperwork, IO shield, wifi antenna, data cable. UPC cut out for rebate.
It has NVMe support and been using it with my Samsung 950 Pro (2500mb/s read with crystal disk mark), the drive is not included.
Bought from Newegg 4/19/2016, so still about 8 months of warranty left. Never had any problem with it.
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157650
EVGA 980 Ti FTW GAMING ACX 2.0 w/ backplate
P/N: 06G-P4-4996-KR
Comes with original box. Bought July 9 2016 from Amazon warehouse deal, not sure how the warranty goes but worst case it would be from the original factory shipping date.
I bought it just to play overwatch, which I played like 3 months...I don't do any GPU computing or video work. its been just serving as a glorified monitor feed for web browsing and normal stuff. Never been used on mining either of course. If I remember it correct, It is also a very good card with pretty high boost. But its been so long and I dont remember what was a good number..
https://www.amazon.com/EVGA-Installed-Backplate-Graphics-06G-P4-4996-KR/dp/B014PXHC6M
G.SKILL Ripjaws V Series 2 x 8GB DDR4 3000 15-15-15-35 1.35v
Model: F4-3000C15D-16GVR
Comes original packaging. Nothing much to say, it is what it is..
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231878
All prices FIRM and includes shipping in CON US. Canada is fine too but additional shipping cost, and custom fee on buyer of course, if any. No package forwarding services please.
980 ti: $240
Mobo+CPU: SOLD
RAM: SOLD
Freebies to the mobo+cpu buyer: some cases fans (2x 120mm, 2x 140mm), a usb 3.0 hub.
Payment: Google Pay> Chase Quickpay > PayPal(you need to have a decent heat to use paypal)
Heat: https://www.heatware.com/u/68318/
Status
