Migrated to an Edgerouter POE and no longer need the X. Works perfectly, used with Google Fiber (and currently configured as such, can reset upon request) with no issues. Included is the box the original 12 volt AC adapter and a 24 volt AC adapter so you can use POE on ethernet port 4 if you don't have POE switches currently.
Edgerouter X - SOLD
For sale are 3 Unifi B/G/N access points. They come with the plastic back plate and PoE injector (24V .5A). 2 of them are missing the metal mounting bracket, however you can just use the plastic back plate for mounting if you were so inclined. They do not have the original packaging or documentation.
3 Unifi B/G/N APs, SOLD to cobramonkey
H E A T W A R E
Edgerouter X - SOLD
H E A T W A R E
