Local Pickup Only, Prices are Firm
Located in northern San Diego County
Change Log
8/01:
Corsair 380T
Alphacool UT60 360mm
AquaComputer Kuplex Kryos HF Socket 1366/1156/1155/775
EK Monarch RAM Waterblocks X4
Klipsch RP-240S Surround Speakers
Damaged:
Change Log
8/01:
- Removed Singular Computers items. All have been sold.
- Removed Corsair 780T info. Item has been sold.
- Updated price on singularity computers reservoirs (copy and paste error)
- Added pictures for:
- Corsair 780T
- Singularity Computer Ethereal Mounts
- Added following items:
- AquaComputer Kuplex Kryos HF Socket
- EK Monarch X4 Water Blocks
- Klipsh RP-240S Surround Speakers
Corsair 380T
- Price: $125
- Condition: Like New
- Protective plastic film has not been removed from the case
- Comes with
- 2 radiators:
- 1 - Alphacool XT45 240mm
- 1 - Alphacool XT45 120mm
- Radiators used only with distilled water
- I might be off on thickness radiator thickness, but it's definitely not 30
- 3 - Corsair SP 120 fans
- Fans sleeved with teleios sleeving
- 2 radiators:
- Mods
- Parts of front of the case has been removed in order to fit 240mm front
- I/O panel has had fan connections removed (plan was to use a run fans off a fan hub)
- I/O panel has been sleeved wtih teleios sleeving
- Price: $100/radiator
- Barely used, only run with distilled water.
- Price: $40
- Condition: Very good, reservoirs have minor scratches
- Color: Nickel plated exterior, copper block
- Only used with distilled water
- Price: $40
- Qty available: 2
- Condition: New/Like New, neither block has been used
- Color: Nickel
- One block is still sealed. The other has opened and modded to make the acrylic clear. Aside from that, it has never been put in a loop.
- Price: $250 for undamaged, $215 for damaged
- Qty available: 2
- Condition: Like New/very good, one speaker has slight damage to the enclosure and parts of the grill are cracked; however, the drivers themselves are fine.
- Color: Ebony black
- Boxes can be included if requested; however, they're not the original boxes (serial numbers do not match)
Damaged:
