FS: 300GB Velociraptor
GLFS. DO you know what the differences are?
BLFS has no heatsink, the SATA connector is located at the back of the 2.5" HDD itself. This is basically the bare drive only.
HLFS has a heatsink and is backplane compatible since the SATA connector is located to the correct location for a 3.5" HDD.
GLFS also has the heatsink but is not backplane compatible since the SATA connector is located at the back of the 2.5" HDD itself.
The GLFS is pretty much the BLFS on the Icepak. I would buy this in a heartbeat if this was the HLFS. But I'm sure somebody here would snatch this up real soon.
gazorp
I sent in two GLFS for RMA because they both failed after less than a month, WD sent HLFS in return and they have been perfect for two months now.
