Is there a freeware or something free similar to Partition Magic? I just installed Windows on a new drive, but forgot to create a second partition. I need to recover the missing 75gb floating around on my drive.
Check out gparted. You'll probably be interested in the livecd. But if you just want to create a partition in the empty space then you can just use the windows disk management control panel.
