Free Copy of SnagIt 7.2.5
morpheus6d9
Although this is the previous version, it's free.
Register at TechSmith.com for a free softwarekey for SnagIt 7.
Techsmith.com
Download a copy of the latest version Version 7.2.5 from OldApps.com.
Download 7.2.5
The same key is used for all registrations. Here is the email they sent:
Thank you for using SnagIt, the screen capture and editing software
that lets you add stunning effects – and helpful instructions – to
anything you see on your PC screen.
Dear SnagIt user,
Thank you for using SnagIt, the screen capture and editing software that
lets you add stunning effects - and helpful instructions - to anything
1. Install the cover mount disc that includes SnagIt 7.2.5
2. Select SnagIt from the list of programs
3. A SnagIt Message Center window will open. Select Unlock.
4. An Enter Software Key window will open. Type in your name and
software key:
YW6RC-4YMK6-SZBBD-C2MCW-Q9D96
Want the latest version? After installing SnagIt 7.2.5, you will be
eligible to upgrade to the current version, SnagIt 8.2, with special
customer upgrade pricing discounts.
Newly redesigned, SnagIt 8.2 makes it easier than ever to communicate
with your audience.
* Add interactivity to your images ... just click on an image to
be directed to a Web page
* Take advantage of the easy printing options
* Completely compatible with the latest operating systems
Since SnagIt 8.2's capture and editing options are so flexible, you'll
immediately add speed, creativity and ease to your everyday tasks.
Upgrade today to benefit from the most advanced version of SnagIt! After
installing SnagIt 7.2.5:
Zener
SnagIt is an awesome screencap utility. I use it all the time at work, too. Now I can have it at home :)
Thanks!!
tHeEvILTwIN
Same here, use it all the time at work. We're still on an older version though, 6.0 I believe.
It'll be great to give this a try, thanks OP!
Juic3
Interesting, thanks OP. Its charging me $19.95 to go to the latest version though.
Axdrenalin
[H]ard|DCer of the Month - Nov. 2009
Free to try is good....I'l take a look.
Thanks!
