Fractal Design R6 w/ front rad, optical drive and HD
ZippZopp
i'm considering getting the r6 for a new build. I need an optical drive in the system and I'm wondering if anyone knows if I can fit a 280mm front mounted radiator (corsair h115i platinum) with an optical drive and a 3.5'' hard drive in the bottom
viivo
I use a Define S which is nearly identical in dimensions to the R6 with a 280mm radiator mounted in the front and, while the S doesn't have any drive bays, there is ample free space, so you should be fine.
edit: I just took a picture to give you a better idea of the space and mounting options:
Apologies for the lack of LEDs.
defaultluser
[H]ardForum Junkie
You should be fine. Here is the case with full installation of front fans and drive trays.
Apparently all 6 hdd mounts are independently mountable. You could mount 2 on the bottom without obstructing airflow.
What the hell do you need a 280mm radiator for cooling 4770k at such a pedestrian overclock on a 95w processor? Overcompensate much :D
ZippZopp
thanks for the pictures...that helps a lot!
I'm doing a new build with a 9900k!
pitingres
[H]Lite
You can download the manual for the R6 from the fractal design website, and it shows all of the various radiator alternatives and what does / does not fit.
Spartacus09
I have the R5 and did this exact setup with a H110i, the tubes are a little tight but not uncomfortably so.
