I don't know it, I'm going back probably tomorrow to check it out, and wasn't sure if there were any external features or certain numbers on the LCD or its box that would determine it, like a range of numbers within the serial number, etc.
Check the vertical contrast shift......if it's a TN, it should shift within a few degrees, but if it's a 8 bit, it will be difficult to notice any unless at extreme angles.
