yes
but the XP cd does not detect a HD on the laptop
If you go to the drive makers web site you should be able to download a free utility to wipe the drive repartition it. To my way of thinking (which could be wrong ) if the drive shows up in the BIOS windows (XP) should be able to see it during the install. It may not be able to handle the partitions format but shouldn't it be able to see the drive? It's looking for the hardware right?
You're wrong. I mean, maybe you did hear that -- but it isn't true.*Correct me if I'm wrong* I heard some where that Vista does something to the drive turning it invisible to anything else (to say, reformat).
