Skripka
- Feb 5, 2012
So I know someone who recently got their hands on a $3000 FLIR (Infrared for those not hip) camera in their department. We wanted to play around and see what we could see…so the idea of scoping a PC waterloop came up to see what it looks like in the infrared.
Instrument is one of these FLIR E-Series: http://www.flir.com/cs/apac/en/view/?id=41372
So first we need to calibrate the scope, and what better way than with ONE Standard Cat. Because if anything shows anything in calibration, it is using a $3000 FLIR instrument sensitive to 0.1*C to look at my house cat Reilly
*So the “Spot ____*C” reading is the temperature in the middle of the reticle. The scale on the right side recalibrates from time to time with the high/low being the maximum/minimum temps in the frame.
Without further ado, the PC waterloop is my sig rig system as pictured below in visible light with a nice DSLR camera for clarity:
Loop order is:
D5 pump->GPU->240mm Radiator #1 with push/pull AP-15s (lefthand radiator in all pictures)->CPU-> 240mm Radiator #2 with push AP-15s (in the right hand of all pictures)->D5 Pump
*NOTE Ambient temperature in my room was measured to be ~23-24*C for comparison
1) First we need a baseline. So I left my machine powered off overnight. So this is as cold as my machine gets without flipping the switch on the PSU
As you can see…Most everything in frame is dark. The only warmspots aren’t that warm peaking at all of 27C or +3C over ambient…those hotspots are the backlit power buttons on the motherboard. Funny note, the acrylic GPU waterblock top is an IR reflector. You can see the IR reflection of the Z68 motherboard chip heatsink bounced off the top of the GPU block.
Now let us boot my machine and see what we can see. Until load tests, all fans were UNDERVOLTED via fan controller to 5V, for silence.
FLIR CONTINUED IN POST #2
