Happy Hopping
- Jul 1, 2004
so the sys. requirement on win 7 32 bit is 1GB of RAM, and for 64 bit is 2 GB. Any harm on a person running an old PC w/ 1 GB of RAM using 32 bit? Or should he take a chance and run Win 7 64 bit at 1 GB of RAM?
as someone wrote this:
https://www.quora.com/Can-a-64-bit-operating-system-be-installed-on-an-old-PC-with-1-GB-of-RAM
If the computer can handle 64bit (i.e. its processor works with 64bit instructions) then it can definitely be installed.
The amount of RAM is not directly related to 32bit or 64bit. Rather it might be that a 64bit OS is designed to make use of more RAM than a 32bit would. E.g. a 32bit would try to restrict itself from using too much, since it can only handle up to 4GB - thus allowing space for programs means it needs to refrain from taking too much for itself.
A 64bit OS can handle much more RAM. So the incentive of the programmers who wrote it is much less to restrict it from using more RAM for itself. Thus you find that many 64bit OSs may use a big portion (if not all) of that 1GB of RAM.
But this varies between OSs, and even depending on the exact variants and/or additives on that OS. E.g. installing something like the lightweight Lubuntu may work absolutely perfectly with 1GB of RAM, while installing the exact same version number Ubuntu would likely use up so much that you cannot run any more programs. But installing something like a headless Debian onto it would be screamingly fast.
I’d say that most (if not all) 64bit Windows versions would struggle in the extreme to work on that. I’ve even found that W10 hardly works on 2GB, let alone 1GB.
