M76
- Jun 12, 2012
So this exploit only works if the remote access feature in utorrent is activated and said ports are opened in the firewall, right? The article seems a bit vague on those details.
Lol, makes sense that it would be a "vulnerability" if you have the options available.So this exploit only works if the remote access feature in utorrent is activated and said ports are opened in the firewall, right? The article seems a bit vague on those details.
Do any other client support automatic file transfers to folders based on label? I have a setup I've been using for a while that requires labels for moving files to different shares/folder automatically. Using utorrent 3.3.1 here.
Except I also have the VM locked down, and a separate firewall protecting the VM from the internet, so it's unlikely they would get very far.
Too many easier targets on the internet for they to waste too much time on mine, and very little payback if they did manage to infect it.![]()
If you're using a torrent downloader on it, I would say your firewall has an attack vector. But you are right. I'm just saying "Most devices connected to the net are exploitable one way or another"
You tell me? Is the most popular torrent client used by anyone?lol what uTorrent gets for going closed
does any one even still use it?
Going closed? when was ut ever open source?lol what uTorrent gets for going closed
Well the webui part of ut is where this exploit happens
qbittorrent has a webui, to control it you can use:
https://github.com/tympanix/Electorrent
https://addons.mozilla.org/en-US/firefox/addon/bittorrent-webui-120685/
Might try Waterfox. It uses the old addons.The second one doesn't work with newer versions of FF, as BlueFireIce said. It's one of the main reasons I'm still on an older version of FireFox. That said, since this topic came up I have been looking at Deluge. It would appear that you can run a thin client on a remote computer and it will point everything back to your server. It's hard to say though as the documentation isn't very clear.
I never updated passed uTorrent 1.61, the switch to Won 10 made me switch to 2.2.0, still ad free but had a massive memory leak, went to qBittorrent nearly 3 years ago now with no problems at all.
To be clear, are you saying uncheck Disable Windows Caching of Disk Writes?utorrent 2.2.1 was and still is the last good version of utorrent once you set everything back to the classic layout.. after that version they switched the adware bullshit due to bitorrent inc. taking over complete control of the software development(there's a bit more behind closed doors for why this happened but it's a long winded story).. as far as the memory leak it all depends on your settings and file sizes within the torrent.. if you're still using windows to control your write caches the memory leak was insanely bad since windows straight up refuses to write incomplete data to disk which doesn't work with how the torrent protocol is designed especially with large single files over ~4GB. easiest config, check override automatic cache and set to 500mb, uncheck write finished pieces immediately, uncheck windows write cache, done..
