Im looking for a very experienced flash mx 2004 pro version flash coder. I have some issues with a flash program i'm trying to create. Causing some problems to make it not deployable. It is created using Flash mx2004 PRO and can only be altered with Flash mx 2004 PRO...keep in mind the PRO version as it uses screens that is only available in the pro version.
If you are an experienced flash coder and feel you can help PLEASE contact me [email protected] there will be a stipend for whoever can fix the issue.
TIA
TIA
