Fittings for G1/2 and G3/8
Pestluder
I'm trying to build a small test setup with an old Asetek pump I retired alongside a X58 system.
The pump uses push-in fittings and I'm having trouble with minor leaks.
Who are making G1/2 and G3/8 treaded soft tubing fittings these days?
Nasgul
I go with Corsair but then again, their fittings are made by Bitspower I think.......Then there's amazon where you can find many brands. I have only one fitting for soft tubing in my system but I got it from Microcenter, made by EK.
Zarathustra[H]
This is soft tube, right?
What is your OD?
I've been very happy with my XSPC 3/8" ID 1/2" OD compression fittings.
If I were to start from scratch I would probably use Bitspower though.
I got all of mine on Amazon. Mostly the seller was TitanRig.
Performance-pcs.com and frozencpu.com has g3/8 fittings but only a few. My pump top is g3/8. i had to get a couple of bitspower reducers for it from ppcs. 1/2inch i would try home depot or the like. I really cant say for sure, ive never used them.
D-EJ915
You should be able to find them at a hardware/plumbing supplies store too if you have no success on finding PC oriented ones as they are standard from there that we adopted.
