Canadian in Berlin
- Sep 8, 2007
Hi All,
I'm planning out a watercooling setup, and would like some advice/feedback on what I have so far after a long afternoon on this forum and google and then checking availability locally....
I'm not PLANNING to Overclock, but at the sametime, if there is the overhead available... why not? The main reason for doing the watercooling is cause I've always wanted to try it, AND I'm sick of hearing the roar of my GPU fan.
Furthermore, if I go to watercooling the need for a case almost disappears, as long as there is some air blowing over the mosfets and the southbridge... correct?
Otherwise the case is an Antec P182, the radiator would live outside the box, the resevoir could go in the 5.25 bays and the pump below as that harddrive cage isn't in use.
Planned setup is:
Resevoir - Pump - Rad - CPU (Q9650) - GPU (EVGA GTX 285 1024MB RAm model)
My first guess at the hardware list, based on prices and availability over here in germany:
Resevoir:
Danger Den Dual-bay resevoir 5.25 - 34,90
I wasn't sure if 1 bay would be enough or not, so for 6 euros more, I can get the dual.
PUMP:
Swiftech MCP355 - 86 + EK X-Top V2 19,90
Puzzled together from numerous sources as being most likely the best for this setup.
RADIATOR:
Feser Xchanger 360 + fans - 124
The swiftech MCR320 is available for 89 euros, no fans. The Xchanger without fans is 99 and comes with 3 S-Flex (convenience order). If the swiftech is better, I could still order it, but with 8 euros shipping and all other parts (except pump) coming from 1 store, the Xchanger is more convenient.
CPU Block:
WATERCOOL Heatkiller CPU Rev3.0 -56,94
+ backplate: Watercool Heatkiller Backplate LGA775 5,90
GPU Block: Danger Den GTX285 VGA Cooler (Revision 1) -99,90
My only concern is which version to take (V1 or V2) to fit my EVGA 285... but the store suggests sending them a picture of the card with the cooler off and they'll make sure its the right one... problem is, then I'm without a GFX card...
Now for the questions:
Tubes:
A User named Cathar posted a fairly good info post which I used to decide on the 13mm ID tubes, none of the 16mm OD tubes had a consistent 13ID, usually somewhere between 12,5 and 12,7 so I went with 19 outer...
Do I need a tube cutter? Or what else works well?
How do I estimate my required tube length? Or should I go with that recommended 15ft (+ distance for my radiator from case)
I picked some Feser 19/13 hoses, sadly only available in pre-cut 2,5m lengths. The 13/10mm hoses from Feser can be ordered by the metre so whatever lenth I want... would that be better/just as good/more economical given my setup?
Fillport:
Do I need one for an external resevoir setup? What about internal? Is there a way to use a filltop without cutting a hole in the case? Does a filltop require additional fittings to be calculated and its own section of hose? (I couldn't find a good explanation for that...)
Fittings:
I decided to go with compression fittings, and am left with a choice between 3 final candidates... the links are to a german site but its pretty straight forward. The first set of Feser connectors says they work with 13mm ID and ANY external diameter (my spidey sense tingles at that), the second set of Fesers are for 19/13 hoses and come in a 4-pack and are a bit cheaper than the Bitspowers which are also for 19/13 hoses.
Is there a difference between them at all?
http://www.caseking.de/shop/catalog...ector-Sets/Feser-Fitting-Set-1-4-Zoll-auf-ID-
13-mm::12610.html
OR
http://www.caseking.de/shop/catalog...uss-1-4-Zoll-auf-19-13mm-4er-Pack::13032.html
OR
http://www.caseking.de/shop/catalog...s-1-4-Zoll-auf-19-13mm-matt-black::14083.html
I calculated the required number of fittings at 12. Regarding quick disconnects: I wasn't able to find anything like those over here, but I don't plan to move the case around at all...
I also found a sanity relieving flow meter would I be better off with something better/different?
http://www.caseking.de/shop/catalog/Watercooling/Controlling/Flow-Indicator-Red::1063.html
Finally, if the pump and resevoir also live outside the case, I found a noise reducing housing for the pump... is that worth it or are they not all that loud?
Otherwise I'm aware I'll need a pile of thermalpaste, lots of patience, and some more planning. I think I'm on the right track but could use a sanity check....
I'll also need to figure out how to get my hands on some .999 silver...
Thanks for your input,
Andrew
Planned setup is:
Resevoir:
PUMP:
RADIATOR:
CPU Block:
Tubes:
Fillport:
Fittings:
13-mm::12610.html
OR
OR
Andrew
