Hey guys, pulled the trigger and got into the SFF game just today, my first day as a proud owner of a SFF machine
specs:
MSI nforce 2 mobo
Athlon 2500+ barton, no oc (i know, i know, a shame with the 2500+)
samsung 80 gb 7200rpm
Sapphire Radeon 9600 128 mb
512 kingston 3200
ATI TV PCI tv tuner
I bought the hsf, mobo, and qpack. the rest i sort of had lying around. cost: $187 before tax
and now the pictures:
Front view. Wow those temp readings are off . I have no clue where to stick the probes for the cpu and the hd. i just kind of put them near their respective components.
The machine it was replacing is underneath, to show 1. The relative size of the Aspire Qpack and 2. That I really needed to upgrade my comp!!! The Qpack is very light- Even when fully equipped it weighed maybe 1/3 of my old hp metal slab. The monitor is a 19'.
Side view, showing my lovely wire work
Other side view. See the Note the thermaltake silent boost- an EXTREEMELY tight fit. I actually had to saw off the top ring of black plastic surrounding the fan in order to get her to fit. thank goodness it did. For reference, the HSF fan is listed at 74 mm high. Otherwise, its suprising how much room there is in there, especially between the front panel and the mobo.
TV tuner, Radeon9600, all that other good stuff.
What my Temp/voltage utility is telling me as i post this. ~41C idle, 53C full load. By the end of the burn-period I hope to be idleing well into the 30's. How do those numbers look for the stock PSU guys? Do you think i can add a dvd drive and another 512 megs of ram?
specs:
MSI nforce 2 mobo
512 kingston 3200
ATI TV PCI tv tuner
