NaturalViolence
- Jan 31, 2010
I'm currently planning a 5.1 setup. I'm on a very limited budget.
My fronts are monopoles facing inwards towards the listener.
For the rears I'm thinking about:
This (Klipsch RS-41 II): http://www.amazon.com/Klipsch-Refer...1?ie=UTF8&s=electronics&qid=1305486744&sr=1-1
Or this (Klipsch RS-42 II): http://www.amazon.com/Klipsch-Refer...hannel/dp/B000TD8XEI/ref=cm_cr_pr_product_top
I might eventually upgrade to 7.1 so in the meantime which one of those do you think would be better suited as rear speakers and why?
