Firmware upgrade question...
Discussion in 'Networking & Security' started by Gibby82, May 29, 2007.
  1. Gibby82
    Gibby82 Limp Gawd
    294
    Aug 6, 2006
    I recently purchased this switch:
    http://www.newegg.com/Product/Product.asp?Item=N82E16833124129
    It'll do what I need, but I was originally going to purchase an open box item at the same price, but someone beat me too it (this is the same one at the normal price): http://www.newegg.com/Product/Product.aspx?Item=N82E16833124046
    My question is simple. These two products seem very similiar, I'm wondering if there is a way to upgrade the firmware and get more switch out of it? Thanks for any info!
  2. Gibby82
    Gibby82 Limp Gawd
    294
    Aug 6, 2006
  3. LANm0nk3y
    LANm0nk3y Limp Gawd
    448
    Mar 28, 2007
    Hmmm. not quite too sure if I'm really understand what you mean by "get more switch" out of it. You could always talk to Linksys tech support if there's such a firmware.
  4. Gibby82
    Gibby82 Limp Gawd
    294
    Aug 6, 2006
    The more expensive one has VLAN, Webview and a few other nice options. I'm wondering if it's possible to upgrade from the cheaper firmware to the nicer firmware with all the options. Get more for the money...
  5. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    Different hardware under the hood. The one with the black face is a newer line. You show the unmanaged one..the managed version of that switch is the srw224g4..which runs about 215 bucks.
    I highly doubt it that they made it that easy to purchase an unmanaged switch..and trick it with a firmware flash into a managed one.
  6. Gibby82
    Gibby82 Limp Gawd
    294
    Aug 6, 2006
    You're probably right. I was just hoping to see if anyone had heard of it. I have read about and currently use a DD-WRT flashed Linksys router, I was hoping maybe the switches had some options as well.
