Notquiteanewbie
- Jan 9, 2004
I attempted to deploy a SonicWall TZ170 Firewall tonight
It seemed to be pretty straight forward, except when I never got a connection to the internet.
I was able to connect to the firewall via web browser and it recognized the LAN
(I only used a laptop to connect to the firewall)
If I plug the laptop directly into the 24 port switch ( C5E ), it shows that a network cable is unplugged. I tested on all 24 ports.
Its almost as if someone shut off the switch
The Switch or Patch Panel is owned by the buildiing
The laptop connection was working earlier in the day, before attempted deployment
Could it be anything to do with ARP tables, and if it is what do i do?
can anyone help me? is this enough info?
