Firewall, Anti-Virus, SpyWare
Discussion in 'General Software' started by cldrane, Sep 23, 2004.
  1. cldrane
    cldrane n00b
    17
    Feb 18, 2004
    Hello all,
    I just wanted to get a few opinions. I'm getting ready to build a new system and would like to know which programs you all think are best. I want good firewall, anti-virus, and spyware programs. I plan to run WindowsXP Pro if it makes a difference. Thanks. :)
  2. HighwayAssassins
    HighwayAssassins [H]ardness Supreme
    5,210
    Mar 2, 2004
    Norton Firewall is the best from my experience, Norton Systemworks will scan for viruses and keep your shit running smooth and Ad-Aware SE 1.05.
  3. t. shuffle
    t. shuffle Limp Gawd
    381
    Jun 11, 2004
    Read through this recent thread.
    and Norton Systemworks usually causes more problems than it prevents, from what I have seen.
  4. cldrane
    cldrane n00b
    17
    Feb 18, 2004
    Thanks for the link to that thread. It was most informative.
  5. Tordek
    Tordek [H]ard|Gawd
    1,765
    Dec 9, 2003
    AntiVirus : Antivir
    Firewall : sp2 Firewall
    Spyware : Highjack this!, Adaware se 1.05, Spybot Search & Destroy, CWShredder, BHO Demon, Spyware Blaster, etc...
  6. Cheetoz
    Cheetoz [H]ard|Gawd
    1,972
    Mar 3, 2003
    Antivirus: AVG PF
    Firewall: Kerio PF 2.1.5
    Anti-Spyware: Spybot and Ad-Aware SE Personal
  7. hulksterjoe
    hulksterjoe older and wiser now
    2,900
    Jan 1, 2001
    One thing to remember ..if you have another running system then make sure you download all the files for your install before and burn them to cd.
    The firewall,antivirus winddows service packs etc and such with the latest updates.. Install these first- before you connect to the internet. you can pick up a worm in just the timeit takes you to log in and download these
