Firepros, dual 3647 & dual 2011 motherboards, ddr3 ram, sas hdds, 200+ thread intel phi gear
cdabc123
quantity discounts available. trades considered.
AMD S10000 (6GB or 12GB) - $140 (small quantities available)
AMD S9000 (6GB)- $65 (medium quantities available)
AMD W7000 (4GB)-$65 (medium quantities available)
Supermicro X11DPL-I -$300 shipped
4gb 1600mhz ddr3 non-ecc for desktop|ad3u1600w4g11-b| $10 each 4 sticks available
hiatchi 2tb hdd (these are 3.5" SAS drives)| works with dell PERC 6/i raid controller| $30 (8 available)
2011-1 combo 2 |24gb ddr3 ecc, intel mobo , dual e5-2670's | $250
INTEL PHI GEAR-
intel s7200ap motherboard | Proprietary board and wiring |$400
intel Compute Module HNS7200AP (no fans) | works with intel h2000g chassis |$450
very barebone h2000g chassis and 4 compute moduals | VERY BAREBONE |$1000
Early es Intel phi | 64 cores, 256 threads, and 8gb of mcdram, |$100 (2 available)
complete running server with 4 cpus| 256 cores, 1024 threads, 48gb mcdram, dual 2100w psu (2 es 8gb chips and 2 es 16gb chips) |$2000 + shipping
PHI GEAR faq's
Q: ddr4 is expensive what do I do!
A: good news! you can run the cache on the cpus in flat mode and you do longer need ram. this is not a joke my server running right now has empty dimms.
Q: why the excitement?
A: the intel s7200ap is the only motherboard available outside of a prebuild system for the x200 intel phis
Q: I hate computers but like these what should I do
A: Buy a full h2000g chassis and 4 compute modules. it will be plug and play.
Q: but does windows like them?
A: in typical windows fashion of hating everything that is cool, not so much. I got it to work in windows when I disabled hyperthreading and im still testing. linux worked flawlessly. Edit: if you disable 4 cores they will work with hyperthreading enabled
timestamps-https://imgur.com/a/ldTOEfc
