Firefox Shortcuts Find
tommo
I doubt anyone has this peeve but whenever I use the find function in Firefox, I want to be able to close it after I'm finished. Is there a shortcut for this? I like to use shortcuts a lot.
Oh and please don't tell me to RTFM unless you've found it in there, and care to direct me to it; I've read the manual.
Zxcs
After 30sec of googling I found it was "escape", google.com, you should try it!
Zxcs
6th one down
Some other find-as-you-type shortcuts
* Ctrl+F or / opens the toolbar.
* Esc closes the toolbar.
* Enter finds the next match, if you are in the toolbar, search box. (Also F3, Ctrl+G.)
* Shift+Enter finds the previous match. (Also Shift+F3, Ctrl+Shift+G.)
tommo
:eek: Thanks.. some people dont use exactly the same strings. You'd think this would be on the Firefox site.
