firefox or IE dont want to goto secure sites.
Tony Montana
Anytime i try to goto or log into a secure site like yahoo mail, g mail, us bank, bofa, it says it cant find the page. or something i looked at all my security setting and i havnt turned anything on the only thing i did last night was put on ad aware and spybot and AVG but i took all of it off and it doesnt work stilll. I turned off the firewall and i retryed, I havnt touched any netowrk settings or security settings.
"Unable to connect
Firefox can't establish a connection to the server at www.google.com.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web."
darknite
somtimes in ie you can set all you security to default levels and it fixes this
tools, internet options, security tab, set all those to default, and in the advanced tab, set to default.
see fi that works
Tony Montana
no browsers work not even opera. its something on the computer, but i havened fucked with the settings or anything.
darknite
so you cant even go to google.com?
try it in safe mode, if you can get on teh inet go to majorgeeks.com and get a prog called winsock fix
run that then reset the puter like it tells you
