SonDa5
- Aug 20, 2008
I want to bypass or eliminate the Actiontec MI424WR that comes standard with the FIOS and HDTV system.
I was thinking about splitting the signal from the source with a motorola signal booster then going dedicated to my DGL 4500 router and sending the other dedicated signal to the Actiiontec router for the HDTV or directly to the TV set top box.
Can this be done?
I don't want to use the FIOS router.
Can this be done?
