To think, I actually cut the heat piping on my mobo last week!
1/2 or 3/8 to Quad 1/4 Tubing Splitter
Originally from:
http://gaming.nexgenis.com/forum/hardware-discussion/230-water-cooling-your-mobo-vregs.html
http://gaming.nexgenis.com/forum/hardware-discussion/231-1-2-3-8-quad-1-4-tubing-splitter.html
Just found this lil baby on Koolance.com
VR-AS40-V06 (MB VReg)
The VR-AS40-V06 is a cooler for ASUS motherboard voltage regulator circuits. It works with the most common ASUS hole diameter spacing, 82mm (3.2"). The VR-AS40-V06 is created from solid copper and plated in gold.
Tubing Splitter, Y 13/10-6mm, Quad
http://www.koolance.com/shop/product...roducts_id=392
Quote:
Koolance tubing super splitter: 1/2" (13mm) or 3/8" (10mm) to quad 1/4" (6mm). Two 1/4" (6mm) caps are included to restrict flow down to 2-3 lines.
Additionally, the SPL-X06Y4 includes G1/4 nozzle threading opposite the 1/4" (6mm) side, and both 1/2" (13mm) and 3/8" (10mm) nozzles are included. Heavy-duty design, with nickel-plated brass compression fittings and anodized aluminum base.
Originally from:
