Alright networking guru's...we are a short time away from completing my new home, and I finally have a home network setup that I am happy with. Basically fully networked the house with cat5e and threw some extra conduit in if I want to upgrade in the future.
Told the electrician to dump everything into my basement and don't install anything else to save some money (turns out it is easy to go over budget when building a new house, so every bit helps).
So....18 drops are now nude in the basement.
My plan is to go as follows:
1) Cable modem to
2) Netgear N7000 (already own) to
3) 24 port switch (need help here) to
4) Rest of house
I will mostly just be streaming movies from my plex server, running file back-ups, transferring files, and running a few security cams.
NOW...my questions.
1) Do I really need a patch panel? Is it worth the extra trouble for a simple home network setup? I don't see many scenarios where I need to "patch" things through. I am dreading making a boatload of short cables to go from the patch panel to my switch. Should I just suck it up and do it? Do those of you with relatively straightforward home networks see the benefit?
2) 24 port switch...I'm not going to need a "fully managed" switch. I was likely thinking just midline "smart" switch. Any preferences here? The choices are overwhelming.
Let me know what you would do!
1) Cable modem to
4) Rest of house
NOW...my questions.
