In no particular order here are a few lingering problems and questions that arose over the course of my 2 day pc build:
Why the hell does closing the processor hinge and plugging in sata power require so much force? Literally spent hours trying to figure out what I was doing wrong on both these steps thinking it was giving me far too much resistance to be normal.
Should I remove the plastic tags on my heatsink cord that have a do not throw away picture and a warranty void if removed written respectively on each?
Does it matter which of the two pci slots I put my wireless n adapter in?
Does it matter if my processor power coord is touching the metal of my cpu heatsink?
My cpu cooler fan didn't fit facing my ram I had to put it on the other side 2 inches away from my back case fan and now they are just blowing right at each other, I assume this is bad, Can I reverse the direction of either fan somehow?
After installing windows 7 ultimate, it's updates, and driver updates my ssd is already out 28gb, is that normal and is there any extraneous data on there that I can do away with?
I still have black bars around my display even after installing latest gpu drivers...whats wrong? Possibly fixed: I set overscan to 0% is that the proper fix or am I loosing resolution?
My power cord is a bit short is it bad to plug it nto an old extension cord or to plug it into a power strip which i then in turn plug into a larger power strip?
It tell's me to install Intel ME Driver when I launch Control Center but the only dl I see is "Intel Management Engine Driver for P67/H67" My board is a Z68A though, do I download anyway?
Is 7.5 a good base score (via Microsoft's computer performance system) for a $1300 computer?
________________________
Components List:
COOLER MASTER Hyper 212 Plus
XFX Radeon HD 6950 HD-695X-CDFC
MSI Z68A-GD55 (B3)
NZXT Phantom PHAN-001BK
CORSAIR Vengeance 8GB (2 x 4GB)
If you can answer any of these questions I'd appreciate it and I'll check them off one by one.
Components List:
MSI Z68A-GD55 (B3)
