zamardii12
- Jun 6, 2014
I have been wanting to pickup FF 15 for a long time, but i've been holding out for the PC version but I think my patience is running out and I can buy it for cheap. When searching Google for "Final Fantasy 15 PS4 Pro," I ran across less than favorable results mostly from Digital Foundry quoted through Polygon saying that the frame pacing is bad, "Lite" mode is 1080p but at a unlocked FPS which tends to be around 40-50 fps according to Digital Foundry.
In summary they basically said "PS4 Pro owners are stuck with either an inconsistent unlocked frame rate that’s well below 60 fps at 1080p, or a higher-resolution 30 fps mode that “gives the illusion of running at a lower frame-rate owing to the frame-pacing issues.”
What are your experiences with it? This was published back in February so I am curious how and if it has changed. I wouldn't mind getting the PS4 Pro version b/c when I played the Xbox One version as a rental it was horrible when the game launched. It looked terrible and the FPS sucked.
