Apr 22, 2004 #1 D Davmx Limp Gawd Joined May 5, 2003 Messages 202 Like, Internet Explorer, AIM, folders, and files. When I open to much, the OS starts to group them. I dont like that. How do I disable the grouping? Oh yeah, im running window xp
Apr 23, 2004 #2 F Flying Fox Limp Gawd Joined Feb 13, 2002 Messages 406 1a) If you are using the new style Start Menu: Click Start, right click on the empty area beside log off/shut down, Properties. 1b) If you are using the classic style Start Menu: Start, settings, Task Bar and Start Menu. 2) in the Task bar and Start Menu properties dialog, click the Task bar tab 3) Uncheck the "Group similar taskbar buttons" option
