W.O.T. Stang
- Aug 4, 2003
For some odd reason one of my folders will no longer let me copy/paste anymore. I can copy fine, but not cut or delete.
If I try to cut/delete paste, I get "access is denied". I checked file attributes, and all are unchecked except "read only" which has a green box filled in (errors if i try to remove it.). I tried the 'Attrib'. command in dos (attrib -r -a -s -h DIR /s /d) and it processed for a bit, and then said "access denied - DIR"
I also tried safe mode, and I get the same error. I made sure i was administrator, and even gave my own account full access to the folder just in case.
Any suggestion on what happened, or how to fix it? I'm running out of ideas here.
