I just installed a 10 port Cisco SG300-10MP in my office, 9 of the ports are already in use. Connected to it are
This single Cat5e is connected to my main HP switch in the basement equipment rack.
Here is what I am pondering...
Both of these switches have mini-GBIC ports that can utilize SFP transceivers and fiber. I priced out 2 MGBSX1 compatible modules along with a 30M multimode fiber patch 'cable' online at under $150. Although it would require at least a couple hours of work (including digging around in the attic and crawl space and drilling some holes), but running the fiber to the basement is very doable.
My question to my far more experienced forum members is if the performance gains would be worth the effort?
My server is in the basement, and despite having an Intel GB NIC in my PC I am seeing read speeds of ~23MBs and writes of ~49MBs to/from my it. My server has teamed GB NICs (802.3ad LACP Layer 2) connected to trunked (LACP) ports on my HP switch.
Would running the fiber appreciably increase my available bandwidth and throughput?
p.s. I have absolutely 0 experience with fiber, but I do own an impressive assortment of tools and have experience wiring houses and running Cat and coax cables.
Thank you for your input.
- PC
- Laptop
- Notebook
- WIFI AP
- B&W laser printer
- Color inkjet printer
- IP camera
- Squeezebox SB3
- Cat5e connection to basement HP 1810G-24 switch
