Here's what I have ATM:
Hardware:
P4 2.6 (sucks ass), will go for 3.0 Prescott in next few days
ASUS P4C800
2 x 512 Kingston DDR400 RAM (ValueRAM )
ATI 9800 XT
Cooling:
MCW5002-PT, 226W TEC on CPU, powered by Meanwell S320
MCW50-T, 80W TEC on GPU, powered by aux ATX PSU
MCP600 rev2 pump
RAD676 with 2 x 120mm Mechatronics G1125S fans, 55 CFM @ 25 dBA
Temps:
CPU: -10C idle, +5C load
GPU: latest RivaTuner shows up +65C / +61C (core/ambient) WTF? My northbridge with MCX159 is 33C! Any ideas on this?
So I'm going for a 3.0 Prescott (SL7KB to be exact) next days, maybe even today. Hoping to get at least 3.6+ speed, since it was already tested with stock HSF at that speed.
I'm hesitant a bit about having oc'ed Prescott with about ~120 of heat and just a 226 TEC. There will be ~31C difference between cold and hot sides, so if I'll have a coolant at 30C, it will be +1C on cold plate, then you can make idea what kind of temps will be on core. I think that will be around +25, we'll see that.
I also decided to grab a 176W Peltier unit to replace that one in MCW50-T. That unit is called Drift and rated at 11.3A @ 24.6V. I think I will get a Meanwell S320-24 if you won't give me a better idea
However, this means more heat to dispasse and, truly saying, I don't really like my coolant temp, it is about +40C.
Possible solutions:
#1
Grab a second radiator. How shoudl I put it to get best results? I think to put it in parralel with first one. What radiator I should get? I think about another RAD676 to make my setup look OK with similar rads.
#2
How about getting Black Ice Xtreme III with three 120mm fans?
#3, very radical
Get two Black Ice Xteme III, and one more pump. Then make one loop which cools CPU with 2x Black Ice and second loop (with own pump) connected to RAD676. How do you like this?
Please give me any thoughts you might have on this.
Hardware:
ASUS P4C800
ATI 9800 XT
Cooling:
MCP600 rev2 pump
Temps:
Possible solutions:
#1
#2
#3, very radical
