Dangman
Ninja Editor SuperMod
- Dec 15, 2005
OMGGGGG it's like we're telepathically connected!!!
LOL!
Oddly enough, you're not the first person here on the forums to say that to me....
Hmmm, let me put it this way: I prefer keeping systems with different functions and roles separate to maximize their best price to performance value. In other words, I would have kept the HTPC and gaming/desktop as separate entities.
Oh and I really don't like the look of that Lian Li case. But if it fit your needs and wants, then I have no problem with you choosing it.
Hmmm, let me put it this way: I prefer keeping systems with different functions and roles separate to maximize their best price to performance value. In other words, I would have kept the HTPC and gaming/desktop as separate entities. In addition, a SSD and SLI setup is not what I personally think is within standard computer costs.
With that said, if the Ultimate Ultimate* All-In-One system with HTPC / Gaming / Desktop was your goal, then fine, it's a good build. It just wouldn't have been my goal. That's all I'm saying.
Audio Path - Motherboard S/PDIF Optical Out
My friend has a Logitech speaker system that already includes a little decoder box for DTS and Dolby Digital so he just feeds the optical out from the motherboard to the Sony A/V and then optical in to the Logitech decoder. Even after the projector upgrade most likely the sound will still be over S/PDIF optical and that is fine since he has only a 5.1 setup so both DD/DTS fulfill that need. The newer audio streams that are lossless like TrueHD and Master Audio will have to wait until they are better supported by video card HDMI, media players, and windows audio path.
My own setup is different though. I do the motherboard internal S/PDIF out to my nVidia video card S/PDIF input, then feed both video and audio over the same 60-foot HDMI cable to my living room Pioneer 1018 receiver, which then outputs video over HDMI to my Samsung 50" plasma. This works fine for my setup and I also get DTS and DD 5.1 channel surround sound, and I can go to 6.1 with DD+ that I already tried and tested with my audio setup. I'm awaiting a pair of speakers to come in and I'll do a full 7.1 channel setup in my living room, but I won't be able to get any 7.1 channel streams because of the S/PDIF 1.5 Mbit/s bandwidth limitation. Maybe I'll find a way to get this going. But so far I'm happy with FFDshow doing audio up-mixing to 5.1 channels anyway.
When you keep systems with different functions and roles separate, I would tend to think it would cost a lot more than just building one system to do everything (thus comparatively having a poor price/performance value).
If you don't like the look of that Lian Li case, would you care to expand on what you would recommend that would fit his needs? I will have three near identical systems to his I will be building.
When you keep systems with different functions and roles separate, I would tend to think it would cost a lot more than just building one system to do everything (thus comparatively having a poor price/performance value). Although having separate systems would be ideal in a home when two things need to be done at once (kids watching movie while you game in other room).
but it is my understanding the audio card needs to encode game sounds into one of these formats (like Dolby Digital Live) to get surround sound through an optical connection. Are you getting full surround sound from games through your digital connections?
I'm fond of this case:
$105 - Silverstone LC13B-E ATX Media Center / HTPC Case
Surround Sound for Games
We didn't have time to check the game sound but we did start up Fallout 3 and it appeared like it had sound coming from all speakers, however we didn't glance at the Logitech decoder to verify if a DD or DTS signal was coming through. It sounded great though and I'll be sure to look at it again when I get a chance.
Ummm, dude spend enough time here in his part of the forum and you would see that you and I are the same when it comes to 80mm fans.@Danny Bui
I forgot to mention my rant about 80mm fans in that SilverStone case. I used those, like 10-years go when building systems and I have a bag of those loud an noisy monstrosities. I would highly recommend 120mm fans for any case or possibly 92mm if there is not enough room for some reason. I'd never buy a case if it only supported 80mm fans in the future, 120mm or larger for me and my ears.
Anyway, my personal choice for a HTPC case, for a case for a totally dedicated HTPC , wouldn't be that Silverstone case I linked to. Like many others, I love the look, layout and features of the Antec NSK2480 case. Not designed for high-end PCs but as a case for a dedicated HTPC, it's one of the best choices out there.
